Date/Time: Mon, 13 Jan 2025 09:33:18 +0000
what datafeed to execute with IB?
View Count: 745
[2017-04-26 19:31:43] |
User15185 - Posts: 7 |
hi,if i have SC datafeed and want to execute trades with IB do i need to pay for IB data as well? thanks Radim |
[2017-04-27 04:13:48] |
We do not think you do. But we are not 100 percent certain about that.
[2017-04-27 10:48:09] |
User25244 - Posts: 123 |
I have the same setup And do not pay for IB data the problem i ran into was IB wont let the trade complete unless u change a setting on the api hth T |
[2017-04-27 17:32:11] |
User603009 - Posts: 9 |
What setting did you have to change in IB to get it to work?
[2017-04-27 18:41:58] |
edit>global chart config>api>precautions>chk bypass order precautions
