Date/Time: Mon, 13 Jan 2025 11:57:12 +0000
multiple instance connection to tws
View Count: 688
[2017-04-26 18:36:00] |
User472677 - Posts: 356 |
how to connect multiple instances of sc to one tws?
[2017-04-26 18:55:47] |
Refer to step #18 here: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
