Date/Time: Mon, 13 Jan 2025 09:25:40 +0000
Option trading strategy backtesting using SC
View Count: 1334
[2017-04-26 18:14:56] |
naqviak - Posts: 22 |
Hi Is there a way to backtest options strategy in SC. I was told that I can get data for options using IB. |
[2017-04-27 05:03:14] |
It depends. Did you want to run a back test using the data of the underlying? Or the data of a particular options contract?
[2017-04-27 11:20:19] |
Back testing on options to see the yield
Date Time Of Last Edit: 2017-04-27 11:20:59
[2017-04-27 17:26:39] |
You can back test a trading system using the data of a particular option symbol. Refer to: http://www.sierrachart.com/index.php?page=doc/Backtesting.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
