Date/Time: Mon, 13 Jan 2025 11:46:38 +0000
EA mt4 convert to ST
View Count: 895
[2017-04-26 14:44:51] |
User494206 - Posts: 44 |
Dear, Is it possible to install an Expert Advisor for MT4 in Sierra chart? |
[2017-04-26 17:46:20] |
No, this is not supported. It will have to be reprogrammed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
