Date/Time: Mon, 13 Jan 2025 11:39:56 +0000
Unable to delete drawings on chart
View Count: 817
[2017-04-26 12:57:14] |
User226486 - Posts: 27 |
Unable to delete drawings on chart from drawings made from another symbol. such as extended line and extended rectangle. this is very annoying as it shows up on all symbols i change to on the chart. chart appears to not see them as drawings. Please help |
[2017-04-26 17:15:16] |
For instructions to delete a chart drawing, refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#ErasingChartDrawings And refer to this section here to prevent the display of chart drawings for other symbols: http://www.sierrachart.com/index.php?page=doc/Tools.html#ShowingDrawingsforDifferentSymbols Also update to the current version of Sierra Chart which lets you delete chart drawings copied from other charts: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-26 19:23:18] |
Hi SC, Many Thanks the update let me delete the drawings. |
