Date/Time: Thu, 23 Jan 2025 00:02:31 +0000
Server side OCO with CQG data feed with AMP Futures
View Count: 2201
[2017-04-25 21:42:14]
User157806 - Posts: 71
Quick question are there server side OCO'S available with CQG data feed with AMP Futures? And if so is the OCO server side for the child orders before the parent order is filled or only after the parent order is filled?
[2017-04-26 05:54:18]
Server-side OCO is supported with CQG FIX and CQG Web API.
Server side bracket orders are supported with CQG FIX only. Complete details are here:
Attached Orders: General Management of Attached Orders
[2018-11-01 03:31:27]
User284663 - Posts: 44
Is this still the case? I am using the same setup and need server side bracket orders?
[2018-11-01 03:40:39]
Server-side bracket orders are gone for good with CQG. They are not supported. They do not work properly and you do not want to use them. Server-side OCO orders are still supported though.
We recommend using the CTS low-cost connection model:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel
Although we say that we are not supporting that, it still is effectively supported and works well.
Date Time Of Last Edit: 2018-11-01 03:42:35
[2018-11-01 03:52:03]
Dear SC please know that in this instance I was referring to server side bracket orders post entry for the case of stop loss.
Please see thread and clarify: Server side bracket orders S/L
[2018-11-01 04:07:17]
Yes that functionality does not require server-side bracket orders. The stop order will be sent to the exchange as soon as the parent order fills.
