Date/Time: Mon, 13 Jan 2025 11:57:47 +0000
Overlap 2 different Cumulative Delta Bars with 2 differentVolume Filters in the same chart
View Count: 1354
[2017-04-25 17:40:47] |
User252419 - Posts: 235 |
I would like to see in the same chart, 2 different Cumulative Delta Bars , one with a Volume Filter A and the other with Volume Filter B. Is it possible? Right now I'm using 2 different charts to see each Cumulative Delta Bar Filtered A and B. But I want to overlap them and see them in the same chart. Thank u |
[2017-04-26 00:51:24] |
User19165 - Posts: 346 |
Yeah, this should be easy and should be part of the indicator instead of having to jump through hoops - this is a basic user expectation. Please see my previous thread on this. Cumulative Delta volume filter as input Date Time Of Last Edit: 2017-04-26 00:52:17
[2017-04-26 06:08:14] |
Follow the instructions here to do this: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=292#Cumulative_Delta_Bars_-_Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
