Date/Time: Mon, 13 Jan 2025 11:56:37 +0000
total bid/ask size in Trade DOM
View Count: 1367
[2017-04-25 16:47:06] |
User929952 - Posts: 3 |
how to display total bid/ask size in Trade DOM? thanks. |
[2017-04-26 05:49:50] |
You need to enable this option: Global Trade Settings Windows: Display DOM Depth Totals (Global Settings >> Chart DOM Settings >> Other>> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
