Date/Time: Sun, 08 Sep 2024 00:00:12 +0000
Drawing line problem
View Count: 577
[2017-04-25 15:47:54] |
User536105 - Posts: 36 |
May I ask how can I draw a horizontal line on a M1 chart and simultaneously can view that line on a maybe M15 chart? Thank you.
[2017-04-25 16:41:31] |
To draw a Horizontal Line, refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#VerticalandHorizontalLines To automatically copy it to another chart, refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-25 16:52:11
