Date/Time: Sun, 08 Sep 2024 01:32:42 +0000
ORDER SENT
View Count: 600
[2017-04-25 14:01:25] |
User33743 - Posts: 83 |
Hi, Would you like to explain to me what does it mean "order sent" " This occurs after closing last position. Screen at the atachment. Best Regards |
[2017-04-25 16:34:17] |
The meaning of the Order Status is explained here: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#OrderFieldDescriptions It means the order has been sent but not acknowledged by the trading server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-04 13:57:27] |
The issue is, trader doesn't put order into this level, thats why I am asking.
[2017-05-04 14:25:37] |
We do not know what you mean by this: put order into this level,
