Date/Time: Sun, 08 Sep 2024 00:17:55 +0000
Number bars visualization
View Count: 1660
[2017-04-25 10:37:39] |
fjgaspar - Posts: 62 |
Hi, I have charts with number bars study. I have font size to auto, because if I choose a fixed size, depending the number and the situation, numbers are too small or too big (even going beyond the boxes). So the text size is set to auto. But in the last bar, the current price gets bold, and doesn't fit the box, so if for example the current number is 2345, you only see clearly 34... The numbers don't fit the box, and there are times that you have to wait until price goes one tick up or down to see if the bid or ask number has 3 or 4 digits. Is there any way to workaround this? |
[2017-04-25 16:25:35] |
Yes you just need to increase the chart bar spacing. And reduce the range of prices on the vertical scale with Interactive Scale Range. Both of these are explained here: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
