Date/Time: Mon, 13 Jan 2025 11:55:01 +0000
ACSIL: monitor new manual orders
View Count: 650
[2017-04-25 08:12:39] |
phaedonk - Posts: 352 |
I'd like to monitor for new orders inputted manually, and then change their targets. I have almost completed this but only with iterating through past orders (per your helpful examples). I'd rather only monitor for new orders. Any insight? |
[2017-04-25 17:03:51] |
The only way to identify what you would consider a new order is to look at this variable from the order: s_SCTradeOrder::EntryDateTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
