Date/Time: Sat, 01 Aug 2026 19:35:08 +0000
Footprint Chart Settings
View Count: 10375
| [2017-04-25 07:02:35] |
| User968091 - Posts: 48 |
Can you please tell me the study type and the correct settings to get the a chart looking like the one attached? Im trying to see something comparable to Marketdelta footprint
| [2017-04-25 16:22:48] |
You need to follow through the step-by-step instructions and documentation for the Numbers Bars study here: Numbers Bars And also for the Numbers Bars Calculated Values study: Numbers Bars: Displaying Numeric Information Below Numbers Bars You need to get familiar with the studies by working with them and reading through the documentation. This is the only way. The image you posted is a very complex multi-chart image. If you have a very specific question, let us know and be as precise as possible with what you need help with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-25 16:23:36
