Date/Time: Mon, 13 Jan 2025 11:45:54 +0000
Change Background color with ASCIL?
View Count: 1124
[2017-04-25 02:31:47] |
CustomIndicators - Posts: 126 |
Is it possible, using ACSIL, to change the background color of a chart? I can't seem to find anything for it.
[2017-04-25 16:56:51] |
You can use this ACSIL variable: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scChartBackgroundColor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-25 16:57:07
