Date/Time: Mon, 13 Jan 2025 11:38:32 +0000
Starting a FIB on the same line as a working order
View Count: 632
[2017-04-24 20:36:59]
User28914 - Posts: 87
Example....I place a limit to buy ES @ 2368.00 - line comes up on the chart. I then try to draw a FIB from starting at the same price but every time I left click, it wants to modify the order, not start drawing my FIB.
Can I disable the left click order modification?
Or any thoughts?
[2017-04-24 20:57:42]
You will first need to disable Trade >> Chart Trade Mode On.
[2017-04-24 21:22:27]
Yes, but then the trade will not show up on the chart. Trying to have both order showing and ability to start FIB on the same price.
[2017-04-24 21:25:25]
Therefore, you need to enable this option on the menu:
Trade Menu: Show Orders And Position (Trade menu)
