Date/Time: Mon, 13 Jan 2025 11:45:30 +0000
Sierra EquiVol chart
View Count: 1565
[2017-04-24 17:45:09] |
User704990 - Posts: 18 |
Sierra has price/volume bars, but they don't display as clearly as a true equivol chart due to equal spacing between bars. Small volume bars should be very compressed, while large vol bars should be overly wide. See pic below. Does acsil have the ability to overcome this width issue via custom charts? |
[2017-04-24 21:11:04] |
There is no way to change this in Sierra Chart because there is a consistent amount of space for each chart bar in the visible chart.
