Date/Time: Mon, 13 Jan 2025 11:50:28 +0000
POINT - variable size
View Count: 1120
[2017-04-24 15:54:41] |
User132748 - Posts: 159 |
Since there are DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE and DRAWSTYLE_CIRCLE_HOLLOW_VARIABLE_SIZE could you also make it possible to draw filled circles (POINTS) of variable size? Maybe you can add sc.Subgraph[].Array[0][] array to POINT drawstyle as its size value? Or maybe it should be new separate drawstyle. Thanks in advance. BR |
[2017-04-24 16:29:47] |
So you mean a variable size nontransparent circle?
[2017-04-24 16:35:54] |
Yes. Same as standard POINT but with variable size. BR |
[2017-04-25 04:51:02] |
OK, we will see about this.
[2017-04-25 06:12:29] |
Merlin - Posts: 83 |
+1!
[2017-04-26 06:10:45] |
This has been released in version 1549.
