Date/Time: Mon, 13 Jan 2025 11:49:37 +0000
EUR showing incorrect volume
View Count: 718
[2017-04-24 14:23:42] |
User94740 - Posts: 333 |
it seems the VbP for the symbol EUR is showing incorrect data. Pls see upload. http://www.sierrachart.com/image.php?Image=1493043706982.png |
[2017-04-24 16:45:23] |
This is a problem that you created by setting the Volume Value Format to a value other than 1. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VolumeValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-24 17:24:55] |
thx, but kind of strange, because everything was ok friday and every single chart had now changed. I could understand it if it were just one chart, but the whole chartbook is something else. pure strange!
[2017-04-24 17:29:23] |
Are the charts linked by using Chart Linking?
[2017-04-24 18:04:45] |
I had thought about the same question and before I queried I checked. Only two of the nine charts are linked, but all charts changed their volume value format.
[2017-04-24 18:33:07] |
OK another thing to check is to see that the Volume Value Format in Global Settings >> Symbol Settings for the symbol pattern is set to 1.
[2017-04-24 19:00:52] |
global system setting was the problem
