Date/Time: Mon, 13 Jan 2025 11:53:46 +0000
Sierra charts not connecting to my broker data feed. S5/Gain
View Count: 1188
[2017-04-24 12:42:45]
User884241 - Posts: 2
Good day,
I use my broker feed for Sierra. I am a S5/Gain client.
I have not been able to connect to the server since the weekend and keep getting disconnected.
[2017-04-24 12:43:13]
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-04-24 14:36:42
GAIN Capital FIX Trading socket (541) | Creating socket. Using TLS 1.2. | 2017-04-24 14:36:42
GAIN Capital FIX Trading: Sending the Logon message. | 2017-04-24 14:36:42
GAIN Capital FIX Trading | Connected to trading server. | 2017-04-24 14:36:43
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-04-24 14:36:43
GAIN Capital FAST Data socket (542) | Creating socket. | 2017-04-24 14:36:43
GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-04-24 14:36:43
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-04-24 14:36:43
GAIN Capital FIX Trading socket (541) | Initiating close of socket by core. | 2017-04-24 14:36:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-24 14:36:43
GAIN Capital FIX Trading socket (541) | Write in progress. Shutdown being delayed. | 2017-04-24 14:36:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-24 14:36:43
GAIN Capital/OEC | Disconnected from the trading server. | 2017-04-24 14:36:43
GAIN Capital FAST Data socket (542) | Initiating close of socket by core. | 2017-04-24 14:36:43
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-04-24 14:36:43
GAIN Capital FAST Data socket (542) | Closed. | 2017-04-24 14:36:43
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-04-24 14:36:43
GAIN Capital/OEC | Disconnected. | 2017-04-24 14:36:43
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-24 14:36:43
GAIN Capital FIX Trading socket (541) | Socket gracefully closed by remote side. | 2017-04-24 14:36:43
GAIN Capital FIX Trading socket (541) | Write has completed. Shutdown being performed. | 2017-04-24 14:36:43
GAIN Capital FIX Trading socket (541) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-24 14:36:43
GAIN Capital FIX Trading socket (541) | Closed. | 2017-04-24 14:36:43
[2017-04-24 12:52:45]
dd45 - Posts: 41
i have same problem
[2017-04-24 13:09:38]
User91630 - Posts: 25
I am also having this problem with GAIN Capital.
[2017-04-24 13:09:59]
dd45 - Posts: 41
not sure what this message means
"This software is not permitted to logon"
[2017-04-24 13:24:48]
dd45 - Posts: 41
fixed prolbem, call gain capital and tell them the problem. they just need to "enable sierrachart" on your account. for some reason it was turned off
[2017-04-24 14:07:45]
Just came back online, thanks mate!
[2017-04-24 16:47:58]
We wonder why so many people have had the Sierra Chart software disabled on their Gain Capital account.
[2017-04-24 17:06:52]
If you are still having a problem connecting to Gain Capital we will need your Gain Capital username. Communicate that to us through an Account Support Ticket:
https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets
