Date/Time: Mon, 13 Jan 2025 09:10:21 +0000
Bats exchange and Gain Capital
View Count: 631
[2017-04-24 04:52:26] |
WarriorTrader - Posts: 245 |
Hello, I am using the sc.GetBasicSymbolData in a study to get 15 oil stocks from the Bats exchange. Just subscribed to the free trial. Having problem getting data. Here are two symbols from the list. dp.bz xom.bz getting: Symbol Error - XOM.BZ is unknown, unavailable, or improperly formatted. FIX reject reason: Unknown contract | 2017-04-24 00:19:11 thx --WT |
[2017-04-24 04:58:04] |
We need to contact Gain Capital about this. There are some details that need to be implemented on our side to make this work properly.
[2017-04-24 05:13:29] |
OK Creating a "Curde Oil" and "Gold" stock tick index similar to the NYSE tick. Will post the custom chart code if it has any relevance to market activity. Here are the symbols: const char * StockSymbol[] = { "bp.bz", "nbl.bz","vol.bz","cop.bz","mro.bz","cvx.bz","eog.bz","sto.bz","su.bz","mpc.bz","pbr.bz","oxy.bz","apc.bz","tot.bz","psx.bz","hes.bz","xom.bz" }; //curde stocks 16 const char * StockSymbol[] = { "gg.bz" , "abx.bz" , "agi.bz", "nem.bz" , "au.bz", "gfi.bz" , "gold.bz" , "sbgl.bz" , "ngd.bz" , "kgc.bz" , "aem.bz" , "ego.bz", "bvn.bz" , "hmy.bz" , "auy.bz" }; //gold stocks 14 Thx --WT |
[2017-04-24 05:26:03] |
We can see that we misunderstood. You need to access this data from the Sierra Chart Exchange Data Feed and not Gain Capital. What version of Sierra Chart are you running? It needs to be a current version of Sierra Chart. And also restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-24 05:26:22
