Date/Time: Mon, 13 Jan 2025 08:38:34 +0000
multiple accounts
View Count: 587
[2017-04-22 21:49:17] |
jizzary - Posts: 177 |
assume i have multiple trading accounts w/ few brokers (some are forex, some futures, some for equities/ETFs) as data feed is per broker and is at Sierra process level (rather than at chartbook level) what will be the right way to trade muluple accounts - install sierra once for each brokers ? i think (in case u can make it) the best is to maintain feed login at chartbook level pls advise. tnx Date Time Of Last Edit: 2017-04-22 21:50:09
[2017-04-22 22:07:43] |
Yes.
