Date/Time: Tue, 14 Jan 2025 11:29:47 +0000
CQG not Connecting
View Count: 1946
[2017-04-22 18:12:08]
User379884 - Posts: 45
I am getting the following error when I am trying to login today. I am unable to get data through. Is this a Sierra Chart or CQG issue?
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-04-22 14:06:49
CQG FIX socket (126) | Creating socket. Using TLS 1.2. | 2017-04-22 14:06:49
CQG FIX: Sending the Logon message. | 2017-04-22 14:06:49
CQG FIX socket (126) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-04-22 14:06:52 *
CQG FIX socket (126) | Socket gracefully closed by remote side. | 2017-04-22 14:06:52
CQG FIX socket (126) | Received socket Close event | 2017-04-22 14:06:52
CQG FIX socket (126) | Initiating close of socket by core. | 2017-04-22 14:06:52
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-22 14:06:52
CQG FIX socket (126) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-22 14:06:52
CQG FIX socket (126) | Closed. | 2017-04-22 14:06:52
CQG FIX: Disconnected. | 2017-04-22 14:06:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-22 14:06:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-04-22 14:06:52
CQG FIX Trading | Disconnected. | 2017-04-22 14:06:52
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-04-22 14:06:52
Thank you.
[2017-04-22 18:23:12]
User787977 - Posts: 5
same problem here. I am glad for this post I thought it was a problem on my local network.
[2017-04-22 18:40:06]
User571607 - Posts: 4
Hi, it seems to be a bigger problem with cqg. i can not log on. I will be grateful for your help.
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-04-22 20:35:47
CQG FIX socket (70) | Creating socket. Using TLS 1.2. | 2017-04-22 20:35:47
CQG FIX: Sending the Logon message. | 2017-04-22 20:35:47
CQG FIX socket (70) | Close event error. Windows error code 10053: Nawiązane połączenie zostało przerwane przez oprogramowanie zainstalowane w komputerze-hoście. | 2017-04-22 20:35:49 *
CQG FIX socket (70) | Socket gracefully closed by remote side. | 2017-04-22 20:35:49
CQG FIX socket (70) | Received socket Close event | 2017-04-22 20:35:49
CQG FIX socket (70) | Initiating close of socket by core. | 2017-04-22 20:35:49
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2017-04-22 20:35:49
CQG FIX socket (70) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-04-22 20:35:49
CQG FIX socket (70) | Closed. | 2017-04-22 20:35:49
CQG FIX: Disconnected. | 2017-04-22 20:35:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-04-22 20:35:49
Thank you.
[2017-04-22 18:48:12]
Seems to be ok now.
[2017-04-22 22:14:52]
Being multiple users are experiencing this, it would be a CQG server-side issue.
[2017-05-13 16:48:35]
Dear SC Team,
it is happening again:
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-05-13 11:44:26
CQG FIX socket (19) | Creating socket. Using TLS 1.2. | 2017-05-13 11:44:26
CQG FIX: Sending the Logon message. | 2017-05-13 11:44:26
CQG FIX socket (19) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-05-13 11:44:28 *
CQG FIX socket (19) | Socket gracefully closed by remote side. | 2017-05-13 11:44:28
CQG FIX socket (19) | Received socket Close event | 2017-05-13 11:44:28
CQG FIX socket (19) | Initiating close of socket by core. | 2017-05-13 11:44:28
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2017-05-13 11:44:28
CQG FIX socket (19) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-13 11:44:28
CQG FIX socket (19) | Closed. | 2017-05-13 11:44:28
CQG FIX: Disconnected. | 2017-05-13 11:44:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-13 11:44:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-13 11:44:28
CQG FIX Trading | Disconnected. | 2017-05-13 11:44:28
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-13 11:44:28
[2017-05-13 18:07:27]
CQG system is down over the weekend now.
[2017-05-13 19:25:43]
You mean it will be every weekend from now on?
Is there some official CQG info about that?
[2017-05-14 02:46:40]
In our experience it is not every weekend.
We are not aware of any official information about this.
