Date/Time: Mon, 13 Jan 2025 08:41:14 +0000
Color change on HLC bar
View Count: 1277
[2017-04-22 17:26:13]
Rino - Posts: 124
I want the close to be a different color on my HLC bars.
When I change, it does change the thickness but not the color.
(In the snapshot it is red)
Even If choose the Global settings I can not get it to work.
Is this available? Am I doing something wrong?
Do I appreciate Sierra?
I can only answer the last question, the answer is yes.
Thanks as always
image1ab.jpg / V - Attached On 2017-04-22 17:23:32 UTC - Size: 166.23 KB - 266 views
[2017-04-24 00:11:44]
You need to disable this option:
Graphics Settings: Color Entire OHLC Bar the High/Low Color (Global Settings >> Graphics Settings >> Other)
Date Time Of Last Edit: 2017-04-24 00:12:02
