Date/Time: Mon, 13 Jan 2025 08:52:52 +0000
daily change
View Count: 887
[2017-04-22 17:10:27]
User204945 - Posts: 2
Is there a study that plots the change from todays close and yesterdays close?
I see a couple of percentchange???? studies but I want just the daily change plotted in a study.
I'm using daily bars in the chart
[2017-04-22 23:01:24]
This is very easy with Daily bars.
You just need to use the Bar Difference study:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=56#Bar_Difference
