Date/Time: Mon, 13 Jan 2025 09:09:48 +0000
data
View Count: 609
[2017-04-22 16:52:25] |
User375253 - Posts: 3 |
Hi, I switched my data feed from cqg to rithmic, but on start up it still tries to log in with cqg and won't connect to my rithmic data automatically. I've erased all my settings for cqg, am I missing a step to do. Thank you, Josh |
[2017-04-22 22:11:32] |
This is now resolved for your account. The settings will no longer automatically change to CQG.
