Date/Time: Mon, 13 Jan 2025 08:43:45 +0000
Transparent chart background?
View Count: 699
[2017-04-21 22:30:43] |
chisel - Posts: 23 |
On a detached chart, is it possible to have a transparent chart background? I would like to open a .jpg file in another Windows application and have the ability to see the .jpg file under the price bars on a chart.
[2017-04-22 00:07:49] |
No, this is not supported.
