Date/Time: Mon, 13 Jan 2025 08:42:58 +0000
VbP peaks and valleys
View Count: 781
[2017-04-21 12:31:06] |
User94740 - Posts: 333 |
I have the setting for peaks and valleys set to draw, but when I export the data using Edit>>Export Bar and Study Data to Text File I fail to see anything regarding this data. Is there a special setting or something I may have overlooked in order to get this data in export?
[2017-04-21 17:44:32] |
The peak and valley lines cannot be exported in this way.
