Date/Time: Mon, 13 Jan 2025 09:14:05 +0000
Options
View Count: 671
[2017-04-21 04:37:39]
User28682 - Posts: 233
2 questions:
1) can we plot an option in a chart?
2) I added a second log in, should I be able to get intraday and historical data? Right now when I open a new chart,
I seem to only get an intraday chart as it builds? Cant get data on the chart going back?
Tom
[2017-04-21 17:24:56]
1. We see you are using TD Ameritrade. You can try. The stock-option format is explained here:
http://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions
2. You will definitely get historical data. If there is any missing data, then follow through the instructions here:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart
Date Time Of Last Edit: 2017-04-21 17:26:39
[2017-04-21 17:26:48]
The link in the prior post has been corrected. Reload this page.
[2017-04-22 05:54:53]
I followed the instructions and am trying to load this option like your example:
UVXY, Apr 28, 2017, 20 Call
This is the symbol right from TD Ameritrade:
.UVXY170428C20
I have tried loading the symbol in both formats, and I get download failed?
Thoughts?
Tom
[2017-04-22 22:01:11]
In our experience, this is what happens. It is not something we can help with. The data comes from TD Ameritrade. You really need to use Interactive Brokers for options data.
[2017-04-23 05:22:05]
I have an IB account. So would it be:
UVXY APR 28 17 20Call as I see it in their stuff
or
UVXY 170428C00020000
Their example for option identifiers:
yr mo day C/P Dollar Strike Decimal Strike
MSFT 10 01 16 C 00047 500
I dont understand their decimal strike.
Tom
[2017-04-24 00:18:58]
The Interactive Brokers option symbol format can be found here:
Interactive Brokers Symbols: Options Format
We recommend using format 1.
