Date/Time: Mon, 13 Jan 2025 07:55:30 +0000
Can't stop a chartbook from opening.
View Count: 1043
[2017-04-20 23:02:22] |
Rino - Posts: 124 |
Hi, No matter what I do I can not stop this chartbook from opening on startup. As you can see it is not even listed. Please help, I give up... Thanks as always |
[2017-04-20 23:05:12] |
It must be that it is being opened with a UDP port command from the TransAct software. Refer to: Chartbooks (Workspaces): Automatically Open a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-20 23:12:05
