Date/Time: Mon, 13 Jan 2025 07:50:41 +0000
MArket depth chart
View Count: 872
[2017-04-20 12:40:17] |
User958609 - Posts: 1 |
is it possible with Sierra to setup a Chart like this one? https://twitter.com/nyse_dot_su/status/854823778492317696/video/1 thank you. |
[2017-04-20 17:59:36] |
Looks like you are referring to the Numbers Bars study. Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
