Date/Time: Mon, 13 Jan 2025 07:37:08 +0000
recompile the studies on the newer versions using the current SierraChart.h header file
View Count: 774
[2017-04-19 15:22:11] |
natanibz - Posts: 135 |
How can i recompile the custom studies on the newer versions using the current SierraChart.h header file ? Thanks |
[2017-04-19 16:52:30] |
There is not going to be a need to do this. We are going to put a new version out today which will restore support for older custom studies. However, you can find the instructions on this page: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
