Date/Time: Mon, 13 Jan 2025 07:51:28 +0000
SC Not Responding
View Count: 600
[2017-04-19 14:18:33] |
User23815 - Posts: 210 |
My Sierra Chart regularly goes into "Not Responding" mode for 5-15 seconds. Twice in the last 30 minutes, but always multiple times during the trading day. What might be the cause of this?
[2017-04-19 17:01:31] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often You need to go through each item one by one. In general, the priority items to work on will be increasing the Chart Update Interval and reducing the number of charts open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
