Date/Time: Mon, 13 Jan 2025 14:40:28 +0000
Volume by price / for previous bar
View Count: 1408
[2017-04-19 08:13:59]
User514370 - Posts: 62
I´m trying to get VBP for previous bar (for the bar before the very last bar).
But "Number of periods back to reference" is not possible set to 1
when "One period based on bar count" is selected as Volume graph
period type. Is there any way how to do it?
Thank you!
imagevbp.PNG / V - Attached On 2017-04-19 08:11:33 UTC - Size: 24.17 KB - 249 views
[2017-05-01 13:49:54]
I believe the solution I am looking for is not possible, if you are not responding for more than two weeks.
Am I right?
Thank you.
[2017-05-01 18:26:36]
You cannot do it just for the previous bar. You can have the Volume by Price study draw volume profiles for each bar and limit the number of volume profiles to 1 day.
Let us know if you need help with what we described.
Date Time Of Last Edit: 2017-05-01 18:27:05
[2017-05-01 22:20:17]
OK, please take a look at the picture I am sending you. There is setting of Volume by price Profile
and the result of this setting. I do not understand why I am getting so many profiles. I have set
Volume Graph Period Type: Multiple Profiles Based on Bar Count
and
Number of Bars Based on Bar Count: 1
So, I believe I should have got only ONE profile. And after that if I set
Number of periods Back To Reference: 1
I would get Volume Profile for the bar before the last bar.
Thank you for your help. Really appreciate it!
imageF.US.CLEM17 1 Min #1 2017-05-02 00_10_18.034.PNG / V - Attached On 2017-05-01 22:19:36 UTC - Size: 88.83 KB - 255 views
[2017-05-02 02:59:40]
You will have a Volume Profile for each chart bar with
Make sure you set this Input to Period Type:
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_MaximumVolumeBarWidthType
