Date/Time: Mon, 13 Jan 2025 08:38:45 +0000
rollover
View Count: 624
[2017-04-19 06:40:24] |
User844406 - Posts: 18 |
Hello, I want to change Futures symbol (NQ, YM, ES) but I wasn´t successful. My chart was NQH17 and I wanted to change it to NQM17 (current month). I went to: Chart Settings - Symbol - Find - Selected Symbol NQM17. The chart started downloading but it failured. I couldn´t find that symbol in option, because there is Instance: SC Forex Data (FXCM). I went to: Global Settings - Symbol settings - Service (I changed to: SC Data-All Services) - Update From Server - OK - but there was no change. How can I set it? Thank you for your help. Dan |
[2017-04-19 06:50:15] |
You need to change Global Settings >> Data/Trade Service Settings >> Service to: SC Data-All Services. After this is done you can then access the symbols for that service through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
