Date/Time: Mon, 13 Jan 2025 08:52:47 +0000
Copy drawing from another chart from another chartbook
View Count: 1191
[2017-04-19 05:32:49] |
Dom7364 - Posts: 257 |
How do you copy from another chart from another chartbook?There is "Chart Setings"- "Advanced Settings 2" which copy drawing from another chart but from the same chartbook, when I need to copy drawing from another chart from another opened chartbook.
[2017-04-19 05:39:20] |
You need to refer to the documentation: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
