Date/Time: Mon, 13 Jan 2025 07:54:53 +0000
Volume Profile - Ticks per bar
View Count: 872
[2017-04-19 02:52:10] |
User997744 - Posts: 2 |
I have a volume profile laid over 390m bars on my product (MJNK) and the settings will not let me reduce the "ticks per volume bar" to 1 - it seems to default to 5. I don't have this issue with other products like ES. It also allows me to set it to 1 on my other MJNK charts. Is there a reason it's not allowing me to do this? Thanks |
[2017-04-19 03:11:33] |
Refer to the documentation about this here: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TicksperVolumeBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-19 17:08:21] |
Awesome, thank you!
