Date/Time: Mon, 13 Jan 2025 08:40:42 +0000
chart settings.session times blnak
View Count: 1160
[2017-04-18 16:52:51] |
User63632 - Posts: 43 |
Most of charts settings>session times blank..although charts are correct from prior settings..please advise
[2017-04-18 21:34:26] |
We are not understanding this. The Chart >> Chart Settings >> Session Times cannot be blank. It would be best to explain what the particular problem is with the chart by not describing settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-18 22:50:19] |
I opened a intra day chart..see image. If right click the chart>chart settings...session times(start,End time) are blank and can not be changed..Since upload image will not work with chart setting screen windows open, I attached a screen shot..hope this is more clear of an explanation. http://www.sierrachart.com/image.php?Image=1492555181528.png |
Capture chart setting.PNG / V - Attached On 2017-04-18 22:45:25 UTC - Size: 160.49 KB - 242 views Attachment Deleted. |
