Date/Time: Mon, 13 Jan 2025 08:49:53 +0000
ECIDeltaV0.5 not working since v1544
View Count: 895
[2017-04-18 12:38:51]
Adam - Posts: 141
Hi getting scsf_ before any indicator since the upgrade but no errors in the log.
The same error is being noted in all the other users of SC i speak with
Adam
[2017-04-18 12:44:49]
User20450 - Posts: 330
same here on update to 44 ver , few custom studies have disappeared
[2017-04-18 13:00:02]
mike327 - Posts: 10
Wondering if this symptom helps. I updated to 1544 last night. I have multiple custom studies running on multiple instances of SC. The one custom study I am using was compiled using the older "sg" code. This study works on the main SC window but not any instances. I have an updated version of this study which I converted to the "sc" code. This version works in the main window as well as in all instances. All other custom studies I am using are "sc" coded and work in the main window as well as all instances. I don't know if this is related or not but it seems reasonable it may be. :) Thanks. Mike
P.S. - I tried the prerelease version download and that did not seem to help.
Date Time Of Last Edit: 2017-04-18 13:01:01
[2017-04-18 13:03:17]
Adam - Posts: 141
agreed im getting issues on the 2nd instance for a DLL but not the primary
Warning: The Custom DLL study "GomOrderFlowPro.scsf_GomOrderFlow" has just caused a CPU exception. | 2017-04-18 13:02:08 *
Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2017-04-18 13:02:08 *
Warning: The Custom DLL study "GomMPPro.scsf_GomMPPro" has just caused a CPU exception. | 2017-04-18 13:02:08 *
[2017-04-18 13:17:17]
mike327 - Posts: 10
Yes. I am also getting CPU exception errors as well on a custom study I have never previously received any errors on. But I am getting the error on the primary as well as the instances.
Warning: The Custom DLL study "TriStar_ZigZagATR.scsf_ZigZagATR" has just caused a CPU exception. | 2017-04-18 08:13:04 *
Warning: This Custom DLL study may cause AT to be unstable until you remove the study from your chart and restart AT. | 2017-04-18 08:13:04 *
[2017-04-18 15:18:42]
The exceptions for the studies in User Contributed Studies which use the Zig Zag functions, have been resolved in the latest release.
Update to version 1545 following the instructions here:
For studies in other DLLs, it is necessary to contact the developer of those studies and have them recompile them for 1544 and higher.
It is only studies which rely on the internal Zig Zag functions which are affected.
The above is documented here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1544
Date Time Of Last Edit: 2017-04-18 15:19:18
[2017-04-18 15:20:26]
Adam - Posts: 141
Thanks guys as always.
[2017-04-21 05:08:05]
Regarding the issues with custom studies, refer to the release notes for 1547:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1547
Additional changes have been made which you need to be aware of.
Date Time Of Last Edit: 2017-04-21 05:08:35
