Date/Time: Mon, 13 Jan 2025 08:39:09 +0000
RTH Hi/Low of Day
View Count: 1421
[2017-04-17 21:40:23] |
Crtfyd - Posts: 281 |
I don't understand why its so hard to code a Hi/Low of the day with "Stairstep" for a time period?? The OHLC Hi/Low works fine for the whole day. I want the RTH Hi/Low of the RTH day. And short of using it on another chart with just RTH hours, THEN overlaying the study creates unnecessary lag. To be clear, as the Hi/Low is happening in real time, the Hi/Low for Time Period plots in "Stairstep" as it goes. But I find as I want to do a "Colorbar on alert condition" study, and I'm putting a condition in of the Hi/Low of the day, it wont work because the "Hi/Low for Time Period" is fixed at the Hi/Low of the day (as a horizontal line) once the day is finished, which doesn't help me for analysis or quick reference. I would have to "Replay" in order to see if my Colorbar studies are working and/or analyze. Why wont the Hi/Low for Time Period study show the "Stairstep" after the day is done, instead of just a horizontal line at the Hi/Low of the day? Thx |
[2017-04-21 18:00:48] |
You need to use the Daily OHLC study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=137#Daily_OHLC And refer to: Daily OHLC: Displaying the High and Low Lines Incrementally for Day And set this Input to Yes: Use Day Session Only Although this might not be what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-21 18:14:32] |
We will see about making a quick change to the Daily OHLC study to have it work like what you are looking for. Assuming we understand you correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-21 19:44:59] |
Thank you. Sorry, to be clear. The Daily OHLC study, and the Hi/Low for Time Period study do not stairstep (even if Daily OHLC study is set to day session) in a SUBGRAPH (Chart Region other than #1 Main) thx |
[2017-04-23 21:23:58] |
We rebuilt the High/Low for Time Period -Extended study with enhancements to accomplish what you want. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
