Date/Time: Mon, 13 Jan 2025 08:50:37 +0000
Add ATR to weekly open
View Count: 1426
[2017-04-17 08:12:37] |
User258888 - Posts: 10 |
Is there currently a way to add/subtract a fixed value to the weekly open? For example, add half weekly ATR to open and subtract half weekly ATR to weekly open to create two lines/bands which don't change after open. Thanks any help appreciated. |
[2017-04-17 20:20:23] |
You need to use the Period OHLC - Variable Period study to get the weekly open : http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=294#Period_OHLC-Variable_Period You can then use the arithmetic studies with the studies that you want to work with in the calculation: http://www.sierrachart.com/index.php?page=doc/ArithmeticStudies.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-18 08:32:08
[2017-04-18 08:26:23] |
thanks, So there are these ATR spikes instead of just bands, So I'd like the ATR value of the weekly ATR added and subtracted from the weekly open, but it wont quite work for me . Thanks for your help |
2017-04-18_09-24.jpg / V - Attached On 2017-04-18 08:24:44 UTC - Size: 114.96 KB - 511 views Attachment Deleted. |
[2017-04-19 20:35:28] |
User700756 - Posts: 16 |
Take a look at this site. I think the visual ATR indicator is what you are looking for. https://sites.google.com/site/beaconcommoditytrading/home/tools-and-indicators |
[2017-04-20 17:55:59] |
In regards to post #3, we will need to get the Chartbook containing no more than two charts so we can see the setup you are using. Here are instructions to provide that: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-20 21:12:33] |
This is a custom study. If you want the dll file let me know and i'll provide it in a separate post. I also attached screen shots of what I think he is trying to do. http://www.sierrachart.com/image.php?Image=1492722681939.png |
SierraSupport - Add ATR to Weekly Open .cht - Attached On 2017-04-20 21:05:19 UTC - Size: 60.81 KB - 497 views |
[2017-04-20 21:55:18] |
We were asking for the Chartbook from the user who posted in post #3 so we can help them with the issue. If what you posted is useful for them, then also post the DLL file as well so they can use that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-20 21:55:39
[2017-04-24 07:33:44] |
That is very useful if I could have the DLL file please. Exactly what I was looking for. Is it customisable (daily ATR as well, multiplier etc) Thanks very much |
