Date/Time: Mon, 13 Jan 2025 11:46:48 +0000
is automatic screen shoting possible??
View Count: 1105
[2017-04-15 15:14:00] |
User30743 - Posts: 365 |
im starting with c++ / acsil and wonder if it is possible to somehow build a study (or something) that would make a printsceeen of my deskotop at the moment i open open and close a possition (at the moment of fillig orders in short)
[2017-04-16 03:34:13] |
Yes. Refer to: sc.SaveChartImageToFileExtended() Did you want a screenshot of the desktop or of the chart? The most Sierra Chart can do is take a screenshot of the entire main window. This function we linked to does not support that but we could add that capability. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-17 10:04:51] |
Marek F - Posts: 244 |
SC, Can you add an option Save Main Window Image to File from Edit >> Screen Images, too? Thank you |
[2017-04-17 10:11:36] |
i use multiple charts in one chartbook (and i use two monitors) so it would be nice it it did screenshot of all what i see (all the charts and both the monitors)
[2017-04-23 15:10:20] |
can u add the function that would make a printcreen of the whole chartbook, not only one chart.
[2017-04-23 18:36:35] |
Only of the main window and we are not sure when we can get to this.
[2017-04-24 19:15:49] |
what do u mean by "main window"?
[2017-04-24 21:32:19] |
The main window of Sierra Chart.
