Date/Time: Mon, 13 Jan 2025 07:49:36 +0000
rithmic data no connection
View Count: 895
[2017-04-14 10:54:33] |
User564972 - Posts: 9 |
I logged onto my platform this morning and all the doms have no depth and the main price charts havnt loaded since yesterday. All my chart settings are exactly the same. What is going on. My rithmic connection appears to be fine. There appeared to be a delay with the dtc bridge server box opening when I open the platform. it says listening socket (296), port 2773 closed. Is it someo ther software interfering with this port? |
[2017-04-14 11:17:38] |
Refer to: http://www.cmegroup.com/tools-information/holiday-calendar.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
