Date/Time: Fri, 31 Jan 2025 09:13:09 +0000
Please increase maximum number of Subgraphs
View Count: 1690
[2017-04-13 22:22:29] |
User132748 - Posts: 159 |
Hi, Since now we have 50/50 depth levels it would be realy great if you could increase max number of subgraphs from 60 to 100. Thanks in advance!!!!!!!! BR |
[2017-04-13 22:48:49] |
This is not something that we would do.
[2017-04-13 23:01:54] |
Is that 60 to 100 increase such a big deal? Mem or CPU load problem?
[2017-04-13 23:19:10] |
It's a very very very very big deal with lots of development and various consequences. It is something we simply will not do.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-13 23:19:28
[2017-04-13 23:24:42] |
OK, thank you
[2019-04-25 07:02:00] |
Ackin - Posts: 1865 |
is the situation in this still the same? I understand it's complicated.
[2019-04-25 07:07:54] |
This is definitively not going to happen.
[2019-04-25 07:28:36] |
ok, I understand that and thank you for your reply I don't want to use subgraphs as array for storing values, but for marking price levels. Perhaps it would be interesting for the future to create something like a "dynamic graphical subgraph by bar size" where values could not be stored, but it would be possible to turn on or off the backlight of some price levels as a traffic light. It is of course possible now, but in big bars it's a problem. But don't deal with it, I was just wonder if there are any news in this. |
