Date/Time: Mon, 13 Jan 2025 07:31:20 +0000
Chart DOM
View Count: 820
[2017-04-13 10:45:45] |
User357295 - Posts: 76 |
Hi, can we change contract directly on Chart DOM ?
[2017-04-13 16:54:40] |
So do you mean change the Symbol? If so, refer to: http://www.sierrachart.com/index.php?page=doc/SwitchingSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
