Date/Time: Mon, 13 Jan 2025 07:35:33 +0000
Time and Sales Settings
View Count: 1440
[2017-04-13 10:42:34] |
User30743 - Posts: 365 |
u should do something with times and sales because everytime i open it is in a different place and has different font settings (different size of lines). why is it so? each time i need to rearrange it.. :-( |
[2017-04-13 16:56:46] |
Once you have the Time and Sales window opened and configured as you want, you need to save the Chartbook. When you reopen the Chartbook, the settings will be the same. Refer to: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html Also refer to: http://www.sierrachart.com/index.php?page=doc/TimeandSalesWindow.html#DefaultSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-15 15:16:46
[2017-04-15 15:00:52] |
no the setings will not stay the same when i have multiple times and sales in one chartbook, tow of them are set to display font size 1 (which is only a tiny link in fact) and two of them are set to display font size 10 (because i need to see the numbers there) everytime i close and open the chartbook i need to set the font size again - because it is either font size 10 for all four TS windows, or it is font size 1 for all four.it never stays the way i want. and of course these 4 windows are totally messed up in monitor.. not holding their proper place |
[2017-04-15 15:12:26] |
This 100% is an operating system problem. Change the [Time and Sales Window] >> Settings >> Select >>Font name to something other than what is selected because you may be using an unrecognized name which is causing the operating system to change the font size to 1. and of course these 4 windows are totally messed up in monitor.. not holding their proper place Once again this is 100 percent an operating system-level problem. Refer to: Window Size and Position Not Restored When Opening Chartbook We cannot provide further help with either of these. These are system issues on your side. Sierra Chart is not going to cause this kind of absurd level behavior. Only Microsoft is capable of this kind of garbage. Although the problem with window positioning, might be due to the monitor setup and video driver you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-15 15:27:02
