Date/Time: Sun, 08 Sep 2024 01:32:03 +0000
modifying extend closes until future intersection to extend the open possible?
View Count: 734
[2017-04-12 18:27:46] |
User63439 - Posts: 83 |
hope title says it all. i know you have a lot of work but hopefully you can do this. thanks in advance |
[2017-04-13 06:33:27] |
We will see if we can easily add this.
[2017-04-13 10:55:31] |
great, thank you
[2017-04-15 15:46:00] |
hey guys, just downloaded the newest release and found what i was asking for. thanks for that. would it also be possible to get this working for the opens of 15 minute bars? |
[2017-04-15 16:00:17] |
We do not understand the question because it works with bars with any timeframe.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-15 16:00:27
[2017-04-15 16:20:16] |
you are completely right, sorry. my question is, if this indicator could be modified to extend the open price of 15 minute bars until future intersection, not the daily open. |
[2017-04-16 01:10:40] |
We will modify the study to support this. It will support extending the Open, High, Low or Close of each bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
