Date/Time: Mon, 13 Jan 2025 06:09:57 +0000
Daily OHLC discrepancies and using Daily OHLC from other charts
View Count: 595
[2017-04-12 15:13:35] |
User565119 - Posts: 33 |
Hi, I trade CL crude, and ES. I use a 1000 volume intra day candlestick chart, and then I use a .10 as well as a .25 range chart. When I plot the Daily OHLC, the range charts do no match the intra day candle stick chart. I tried to tell the study to use the canddlestick chart, but it would not plot them correctly on the range charts. Any tips? |
[2017-04-12 15:41:07] |
Make sure the charts use the Same Session Times: Chart Session Times And make sure for both of those Intraday charts that Chart >> Chart Settings >> New Bar at Session Start is enabled. If there still is a problem, then you will need to set the studies to refer to a Historical Daily chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
