Date/Time: Mon, 13 Jan 2025 06:25:04 +0000
How far back does Sierra Data go
View Count: 590
[2017-04-12 15:12:11] |
User316362 - Posts: 210 |
for ES continuous contract?
[2017-04-12 22:12:58] |
The data goes back to June 2008.
[2017-04-12 22:14:11] |
However, because you are using Transact and those symbols use single-digit years, there is going to be a limitation of about five years back from the current date. You need to install another copy of Sierra Chart and use it with the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
