Date/Time: Mon, 13 Jan 2025 06:08:48 +0000
Looking for CFA Franc
View Count: 769
[2017-04-12 09:53:51] |
User898612 - Posts: 4 |
I am looking to trade on the CFA Franc - Do you have the feed? There are two symbols Xof and Xaf if you don't then would you know on which exchange the CFA franc is traded? Thanks in advance. |
[2017-04-13 00:38:03] |
For reference, this is what you are referring to: https://en.wikipedia.org/wiki/CFA_franc Sierra Chart provides historical daily data for these symbols. Here are two of them: ^EURXAF ^EURXOF The rest of them are listed in File >> Find Symbol >> Secondary Forex. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
