Date/Time: Mon, 13 Jan 2025 06:19:55 +0000
Renko Charts.
View Count: 783
[2017-04-12 06:42:42]
fjgaspar - Posts: 62
I come from Multicharts and I have a question about Renko Charts. In Multicharts, there is a parameter to stablish the box size, and another for the resolution. The resolution is the time between renko box prints. That way, instead of print boxes in real time, Multicharts prints several boxes at a time depending of what have happened during the resolution parameter. Thar resoution may be time (i. e. 1 minute), tics (i.e 50 tics), range (i. e. 2 tics). If you chose range and that range is the box size, then boxes are printed in real time.
In Sierra, I have seen Renko bars have only box size parameter. Is there any way to do the same than Multicharts does?
[2017-04-12 07:51:09]
No, this is not supported.
